Friction Noise From Rear Ke25
Hey guys hope you can help me out here
After I flipped my leaf springs back up the right way I started to get a whirling / wining noise coming from the rear.
It's not a howling noise like a bad wheel bearing. It's more of a friction noise.
It's hard to word it right sorry
It's on deceleration under 60 but constant above 60 and the faster I go the louder it gets
Being a wagon it sounds amplified and I can't stand to go on the highway.
I got under the car and I could move the tail shaft a fair bit and I could move it back and forward.
My uni joints are solid with no play.
Hope this vid works
View My Video
If that didn't work here is a pic of where the movement is coming from I think.
I have a ke35 diff if that helps
QUESTION 2
My diff has moved over to the passenger side
My back pass side wheel sticks out 30mm
My drivers side wheel sticks out 18mm
Why?
Pinion nut is loose, take the tail shaft off the diff and you'll see a big nut, you'll need to tighten this up.
specs.pdf
Edited by TRD ke70
specs.pdf
Wow i didn't think it would be that easy
Thank you so much I really appreciate your help
So my pinion bolt was talked upto spec
But the whole shaft has play in it.
What would be the cause?
Did you loosen it a little before doing it up?? If not, try that. Make sure you smack the locking tab flat before doing it, and make a bar to bolt onto two bolt holes and take up the leverage as you turn the socket.
The pinion nut pushes two thrust bearings together, they locate the pinion shaft in the diff. Between them is a crush tube that should keep them the right distance apart at the correct toque to get an oil film on the bearings.
However you actually do it up until you get a certain torque friction when the shaft turns, just like doing the front wheel brgs to a touch of play. It measures the friction as the pinion turns, but not the crownwheel, so its only a few mm movement.
I think you're up for a full diff strip, but start with taking out the front bearing & crush tube and seeing what is wrong. If the bearing surfaces look OK then try doing it back up. In theory you always need a new crush tube, and you will need the torque friction for when it is correct. Its only an inch.lb measurement, so you might have to make a little weight set on an arm to measure it. Its the pinion pre-load, if you can find the data for it.
If the nut was always tight then something sad has happened inside.
Edited by altezzaclub
