July 13, 201610 yr comment_705456 hey everyone I have a jap diff in my corolla just wondering what I have to do to put a borg warner diff in it as I can't find any japs diff? is it just the diff and tail shaft I have to replace ? j wanting to know cause I want to weld one up Report
July 13, 201610 yr comment_705457 Hi Sean, No issues as spring mount centres are the same. Must use appropriate tail shaft, as the flanges are different on JAP & BW diffs. If you get hold of a BW diff, makes sure it has the larger 9 inch brake drums. The JAP ones were only 8 inch dia. Cheers Banjo Edited July 13, 201610 yr by Banjo Report
July 13, 201610 yr Author comment_705460 cheers mate i thought that was all i needed but just wanted to make sure Report
July 15, 201610 yr comment_705486 Banjo, I thought only the KE55 Borg Warners came with 9" drums? Report
July 15, 201610 yr comment_705495 ^^^^^Late ke30's (late 1977, early 1978) were the start of the borg warner diff with the small drums, cheers! Report
