COPs on K Series Engine
Hi Dave,
              Those COPs I used are still on ebay for less than $ 17.00.   They are stocked here in Australia, so it only took 3-4 days to get hold of them, & postage was free !
http://www.ebay.com.au/itm/4x-Ignition-Coils-for-Toyota-Yaris-2005-2013-Prius-Echo-1NZ-FE-2NZ-FE-1-3L-1-5L/282068263689?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Cheers Banjo
very nice work. I'm doing my second 'learn to solder' project and the next one I buy will be  a megasquirt I reckon....
What options have you looked at for crank triggers?
Edited by philbey
jeesus christ and here i am thinkin I'm all clever workin on making my carburettor automatic variable mixture.
this is just insane.
total respect from me here, I'm impressed, i don't think i could bring myself to manufacturing all the parts to make this engine efi or electronic spark.
just seems so difficult
I finally got my 4 Wire connectors yesterday, for the Echo/Yaris CPOs, I am using .  What a drama !
5a0178caf213f_COPConnector4wireidentification.jpg.6f13c0dd707c126d8eef41119eb50521.jpg
Just wiring them all up on the head & frame I made.  Used a micro programmed to four outputs, at any rate (rpm) I want, & with adjustable dwell.
Went searching for what sort of input voltage/ current is required for the IGT (trigger) input.
Came across this video.
https://www.scannerdanner.com/chapter-22-no-spark-troubleshooting-ignition-coil-module-testing/154-operation-and-testing-coil-over-plug-ignition-4-wire-toyota-lexus.html
If you are interested in how the COP system actually works, as a few respondents to this post have; then this video is a must.  It actually refers to the Toyota COPs used on the Echo / Yaris.
Cheers Banjo
Edited by Banjo
