September 5, 20179 yr comment_711202 Hey guys, Just getting some thoughts from those with experience. Will 13x7 -1 offset wheels fit under the front and rear guards of the ke25 without lipping or flares and what tyres would I need ? Cheers Steve Report
September 8, 20179 yr comment_711270 They will fit, would need a little bit of tyre stretch and yes ideally the guards would need to be rolled if you want to lower it. Report
September 10, 20179 yr Author comment_711310 Thanks for the reply. I test fitted the wheels on the weekend. On the rear, the edge of the rim is flush with the rear guards but should work with stretched tyres (185 ??) and rolled lip. On the fronts, the inside of the wheel fouled the outer edge of the floating side of the brake caliper, needs a 10mm spacer to clear which will mean it will need flares, rolling it won't work. OR I can shave 10mm off the caliper, which "shouldn't" affect the performance by the looks of it. Report
November 12, 20179 yr comment_712115 I'm running the same size rims on my ke10 with 175 50 13 Yokohama tyres. Only difference is my front rim width and offset. Report
