September 9, 20179 yr comment_711287 G'day I've just bought a ke30 and am look for a suspension up grade and want to go to 5 stud. fab work isn't to much of and issue but budget is, what options do I have? Cheers Edited September 9, 20179 yr by jakeyboyke30 Report
September 14, 20179 yr comment_711381 No real reason unless you want bigger power and need a bigger rear diff. For the rear Hilux axles work Report
September 14, 20179 yr Author comment_711385 Will be doing a engine swap down the road but right now it's more for rim choice also am looking and putting weld on coilovers on the front and stiffening up the rear Report
September 14, 20179 yr comment_711386 To be honest, most wheels that are on the market you can find in 4x114.3 these days. If not, you'll find a copy that's almost the same :) Report
