Hey everyone,
I'm gearing up to do a turbo 4age conversion in my KE35 coupe and am looking at different gearbox options.
I've found adapter plates etc for a W55 to bolt to a 4age, but does anyone know if it will fit in the KE35?
I have no problem custom making mounts etc, I just need to make sure it will fit in the car itself.
or is there another manual 5 speed box you would recommend that would handle roughly 300hp?
I appreciate the help.
  • 5 months later...
It will probably come close with some tunnel bashing, or get the MIG out and make the tunnel bigger.
Youve got alot of problems to solve to make a 300hp ke35 not feel like a death trap.
My brothers 300hp  well setup S13 felt insanely scary as a passenger. Was ok as the driver, but man 300hp in a light car is a scary thing.
Yeah 300 is high for a 900kg car, but it's not going to be a mild build, I'll be going over the car from top to bottom, basically gutting it and replacing and upgrading everything including suspension and steering, probably roll cage too, building with a mind to race.
