Hi all, I have a 1981 KE70 and need to know what gearbox oil to use (it has a 4k engine with a 5 speed manual trans). I have done quite a bit of research in the forum, but I need to be sure
Is it 80W90 or 75W80 or something else? Any other variable to worry about when choosing the oil?
Thanks! Looking forward to your answers
Don't over think it. I usually just consult the penrite oil product guide when looking at oils. 80w90 seems to be the go. Any brand you like. These days I generally just buy a brand  name that is on special. Reality is any "Mineral manual gear oil" will do the trick.
They all smell just as bad in gear oil:)
Edited by ke70dave
  • Upvote 1
That was fast, thanks! I'll go with that then.
What made me doubt was seeing a couple posts here on the forum saying that you should't use 80W90 unless it was going in the diff. I guess you can use it for both.
Anyway, thanks again! Greetings from Argentina
Do not use gear lube with a GL-5 or GL4/5 rating. Only use GL-4 or GL-3 in the trans. Using a lube with the GL-5 rating long term will destroy your syncho's in the these older trans designs that have brass alloy syncho's.  DaveW
