June 21, 200620 yr Author comment_124544 /* UP-date */ Completed for mild restoration for the engine which including timing belt, water pump gasket ( the pump still worked), clutch plate and oil seals. Check his out :) Put back timing belt cover Water pump gasket replaced New clutch plate inside the GB Previous clutch plate, the Jappo really thrash the GB :y: Report
