Blue_rolla Posted May 27, 2006 Report Share Posted May 27, 2006 how do u change a clutch on a ke55 with a 4k???? Quote Link to comment Share on other sites More sharing options...
chrisandliz[RL] Posted May 27, 2006 Report Share Posted May 27, 2006 how do u change a clutch on a ke55 with a 4k???? i have a ke 70, and on a ke 70, i drop the drive shaft. then remove the gear selector and pull out the clutch cable and then disconect the revese lights , and the the bell houseing, and if i have not forgot any thing it should just pull off. :( Quote Link to comment Share on other sites More sharing options...
Redwarf Posted May 27, 2006 Report Share Posted May 27, 2006 Purchase a Gregory's manual and it will give you a step by step guide on how to do the job. Quote Link to comment Share on other sites More sharing options...
Teddy Posted May 28, 2006 Report Share Posted May 28, 2006 1) car on jack stands / hoist & drain tranny fluid 2) undo 4 12mm tailshaft nuts 3) remove center tailshaft bolts (2x 14? 17?mm bolts) 4) pull tailshaft out 5) remove gearstick selector 6) undo speedo drive and reverse light off gearbox 7) disconect cable clutch assembly off box 8) undo all the bellhousing bolts, push starter motor out of way (to front of car) 9) undo rear engine gearbox mount 10) remove gearbox 11) remove 6 12mm bolts on pressure plate 12) remove pressure plate & clutch plate 13) remove flywheel & get machined (i doubt you have a dial gauge) 14) remove and replace rear main seal and spiggot bearing (rear main seal is the seal around back of crankshaft, its easy to get too, worth only a few bucks, and is most likely leaking) - Spiggot bearing is the little one that sits in the middle of the flywheel Also, Replace the throwout bearing while your there. 15) Put flywheel back on (tighten to correct specs - RE: GET A GREGORIES BOOK FOR THESE ! 16) put pressure plate and clutch back on, align clutch with approraite clutch aligning tool 17) tighten up pressure plate correct way, evenly 18) put gearbox back in straight, and make sure you don't bend clutch hub. 19) Re the rest of the instalation steps. Quote Link to comment Share on other sites More sharing options...
