Pretty straightforward-  Screws into plastic clips in the rubber strip across the car under the bonnet, tabs on the scuttle panel that slide out under the screen.
Clean the box out the best that you can, a lot of leaves and dirt gets in there and hold moisture in so it rusts.  Oil the joints in the wiper arms while you're in there too.
I can't remember if you HAVE to take the bonnet off, or if it just helps to make it easy. I'm only taking the scuttle off when I have the bonnet off anyway.
  • Like 2
