Stick44 Posted July 8 Report Share Posted July 8 Hi,been a while... Question....How do you remove the little Clip on the window winder? as I have this 'Clunk" sound every time I turn a corner sounds like something loose and hits the window inside the Driver-side door? I got this u shaped tool from Supacheap...but I can't get it.. is there a trick or special way to get it out ?( I pulled eveything else off but this pin) Quote Link to comment Share on other sites More sharing options...
Banjo Posted July 8 Report Share Posted July 8 (edited) Hi Neil, I gather you are referring to these little clips, that hold the window winder handle in place ? You need to make a simple hook, out of an olde thin wire coat-hanger. Push the door panel in hard, just above the handle, & you will be able to hook the pin on it's loop, & extract it. Has always worked for me. P.S. A thin long nosed pliers can also be useful. Hope that assists ! Cheers Banjo Edited July 8 by Banjo Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted July 8 Report Share Posted July 8 And if that doesn't work, use a tea towel. Yes, a tea towel 😉 Quote Link to comment Share on other sites More sharing options...
