20v Missing Hose?
Need help. A hose fell off my silvertop 4age and I don't know what should go there, or where it should go. It is on the rocker cover RHS looking from the front. My car runs microtech so I don't have an air box, I have looked at some photos of similar motors the hose runs into the air box . I don't have one so where should I run it? Should I run a short length of hose to a small filter ?
Normally it will run into the inlet manifold, you could put a filter on it but run the risk of oil spray (a catch can might help) but make sure you hide the filter as it is a requirement to have it circulated back into the engine.
Thanks for the info, I will take care of it soon cheers.
is it required to run back through the engine in all states? here in NSW, i have seen some cars with fan$y catch cans which are pretty $howy
