Most of us know that a KE10 is K= K-engined, E= Corolla, 1= Series 1.
So a KE30 is a 3 series, KE55 is a 5 series.
What happened to the KE40... the 4th series??
2T-G, 2T-GR
Head #: 11111-88222
Head: Second 2T-G®, alloy inspection plate
Cam Cover: no "1600" -space used for vacuum solenoid, "Toyota" on left. Steel gold oil cap on left. Wrinckle black.
Camshafts: 256 degrees duration, 10.27mm lift
Valves: 44.5mm intake, 38.5mm exhaust
Pistons: 8.8:1 (88224)
Fuel: Solex Mikuni 40mm sidedrafts, adjustable fuel levels
Power: 115-125ps @ 6400rpm
Torque:
Bore x stroke: 85mm x 70mm = 1588cc
Aplication: TA22 Celica GT/GTV, TA27 Celica GT, TE27 Levin/ Trueno, TE37 Levin, TE47 Trueno GT
Dates: April 1973 to Nov. 1976
other:8mm exhaust studs
http://www.geocities.com/Colosseum/4883/2tg-info.html
