When To Rebore
hi boys, i'm rebuilding a 3tc and i was going to keep it under $200 if posable.
i pulled the head off and the bore is ok , but how bad does it have the be to rebore??
i can just fell a tiny lip.
i what your ideas :lolcry:
this motor is for the sort term, btw
  • Replies 39
  • Views 11.1k
Get her done properly, saves you from pulling it apart down the track.
Just my 2c,
Brad
lol, a rebuild for under 200
hahahahahaha
is the bore glazed?
thats when it needs to be honed, but if your using new rings you need to rehone as this is what beds the rings in
reboring isnt nesecary unless its been honed a few times or is well worn...
Edited by love ke70
what sort of rebuild are you talking?
ill give u the price of my 1ggte rebuild, 24 valve straight 6 admitadly...
redo valve seats and faces
skim head
deck block
balance bottom end
lighten and reface flywheel
hone bores
regrind crank due to excessive wear
~1200 (done by jack brothers racing, one of best workshops in qld)
would be about 450 cheaper if i didnt balance and lighten flywheel and regrind crank... but have to regrind, so have to balance...so why not lighten flywheel right :lolcry:
then,
h/g
head bolts
thrust washers
timing belt
~340
then
bearings
rings
valve stem seals
cam and crank seals
~500
obviously a 3t parts will be cheaper/more available but its not cheap brother, its not cheap
well this motor is short term motor
so i don't want to waste money on it.
Depends chris,you can de-ridge and hone it,re-ring it until you have the money to do it properly and it may go for ages.
Find a better engine thats running, new gaskets and welsh plugs and use that. If you want machining done it is going to cost a fair bit...
You can rebuild a K motor for 500 andy... if you know the right people...
price check on head gaskets, 4k vs 1ggte
hmm, thats 17 vs 104.95
everything more expensive for my engine....
like, i bought 2 sets of 4k rings
2 sets of 4k big end bearings
2 sets of 3s main beaings
coz thats cheaper than genuine and theyre the same size :)
but yeah...my engine is f@$ked...for a week or 2 more anyway :lolcry:
coz thats cheaper than genuine and theyre the same size ;)
but yeah...my engine is f@$ked...for a week or 2 more anyway :)
i got mine for 13.75 for the 3t and 9.95 for the 4k. :lolcry:
but i'm still trying to get some rings at a good price :(
can't be stuffed paying 50 to 70 bucks for them ;)
any way, i made a new contact that may come in handy. This chick my wife sells avon to works in the toyota distribution centre.
well there is no better way to be a tight ass than networking :D
and you can quote me on that!!! ha ha ha
i got mine 4k re-build done for $450 but i should not have used a gregory's maunal to put it back together!!! they make you take more wrong turn than a drunk'n taxi driver!!!
the cursed book made three misstakes on one frig'n page!!!
for cheap shit talk to a company called STA parts, in NZ
theyre utter shit in the customer service department (and had 4 oversized 1ggte pistons in stock...go figure that one!) but by golly miss molly they have some good prices!!
