July 15, 200620 yr comment_128564 Hi, I just joined up and am looking for insiration to finish my ke20 as well as other people that have done simialr things. In breif, I am using a 4AGE bottem end(crank,rods,pistons) in a 5k block with holden V6 roller lifters, roller cam(obviously), 3k big port head(extensivly ported and modified combustion chamber), Hawk EC21 ECU and SC12 supercharger. I have gotten caught up with 355 holdens and need to get motivated to finish this project as the engine itself is ready to assemble. All I need to do is make up the brackets for the blower and finish the inlet manifold. I will post some pics up very soon. Cheers, Matt Report
July 15, 200620 yr comment_128576 Hi, I just joined up and am looking for insiration to finish my ke20 as well as other people that have done simialr things. In breif, I am using a 4AGE bottem end(crank,rods,pistons) in a 5k block with holden V6 roller lifters, roller cam(obviously), 3k big port head(extensivly ported and modified combustion chamber), Hawk EC21 ECU and SC12 supercharger. I have gotten caught up with 355 holdens and need to get motivated to finish this project as the engine itself is ready to assemble. All I need to do is make up the brackets for the blower and finish the inlet manifold. I will post some pics up very soon. Cheers, Matt Get me pics my man and ill give you all the inspiration you need. TRUST ME!!!!!!!!!!!! Report
July 15, 200620 yr Author comment_128583 This is the crank, It has been welded on all the mains(on a gleeson welder specificly for welding cranks) to build them up 1mm and was stress relived, The nose was shrtened and bolt hole deepened, the shaft then spent a day in our CNC mill getting profiled,knife edged and radiused which removed 3kg's from memory. It was then re stress relived, dressed and shot peened, then ground and nitrided. All up probably 60-80 hours of work in the crank alone. The rods are just std 4AGE and have been dressed, shot peened, fitted with 3/8" ARP bolts, resized, aligned, small ends were re bushed and offset pin bored to get the correct deck height without having to deck heaps off the block. Theres not much I could do with the blower apart from pull it apart and check/clean it then paint it. The block had to be relived to fit the fully counterweighted crank but its nothing special to look at, it has also been line bored, bored, honed, and decked. Report
July 15, 200620 yr comment_128593 This is the crank, It has been welded on all the mains(on a gleeson welder specificly for welding cranks) to build them up 1mm and was stress relived, The nose was shrtened and bolt hole deepened, the shaft then spent a day in our CNC mill getting profiled,knife edged and radiused which removed 3kg's from memory. It was then re stress relived, dressed and shot peened, then ground and nitrided. All up probably 60-80 hours of work in the crank alone. The rods are just std 4AGE and have been dressed, shot peened, fitted with 3/8" ARP bolts, resized, aligned, small ends were re bushed and offset pin bored to get the correct deck height without having to deck heaps off the block. Theres not much I could do with the blower apart from pull it apart and check/clean it then paint it. The block had to be relived to fit the fully counterweighted crank but its nothing special to look at, it has also been line bored, bored, honed, and decked. Ok so what now,have you done a dummy up of the rotating assembly to make sure it all turns ok. What cubes is the engine now with all this done. 1650 or there abouts. Give us a look at the cam and head,then assemble the engine and get it going alreday. can't wait for this. Edited July 15, 200620 yr by madrolla68 Report
July 15, 200620 yr Author comment_128596 Ok so what now,have you done a dummy up of the rotating assembly to make sure it all turns ok. What cubes is the engine now with all this done. 1650 or there abouts. Give us a look at the cam and head,then assemble the engine and get it going alreday. can't wait for this. Its all been dummied and all is good, Cam and head are still at my old work. its now 1600cc. Report
July 15, 200620 yr comment_128601 Its all been dummied and all is good, Cam and head are still at my old work. its now 1600cc. Ok man get it happening ,we need to see how this combo works, Report
July 15, 200620 yr Author comment_128607 Ok man get it happening ,we need to see how this combo works, yeah its been happening for 5 years now, which is why I need the motivation. Thanks for the kick in the arse so far mate :lolcry: Report
July 18, 200620 yr comment_129055 mate i've got a ke20 and a 4agze to put in it, I'm in the same boat for motivation, i have alot of things to do but not sure were to start.. Good luck mate look forward to seeing the future piccies... Report
July 19, 200620 yr Author comment_129266 mate i've got a ke20 and a 4agze to put in it, I'm in the same boat for motivation, i have alot of things to do but not sure were to start.. Good luck mate look forward to seeing the future piccies... Yeah thatnks man, I'm thinking I should have just used a 4AGZE in the first place, would of cost a hell of alot less thats for sure, and would of saved re-inventing the wheel. Good luck with yours. Report
September 21, 200620 yr comment_142215 how has progress come along with this engine? if it has come along at all? this thing will be fukin awesum ina ke20, stamp the original 3K numba on the 5k block and go confuse some coppers. awesum work so far champ, don't stop now. cheers scott Report
September 21, 200620 yr comment_142217 What more inspiration could you need, This thing is going to be absolutely nuts!! Talk about bragging rights.. Report
December 2, 200718 yr Author comment_212742 Anyone interested in buying this engine minus the roller cam?, the bottom end is 100% ready to be assembled. and the head is 10 mins work away from being ready to fit. Only thing i would do different if I was to finish the project is go turbo not blown. Report
December 3, 200718 yr comment_212774 Anyone interested in buying this engine minus the roller cam?, the bottom end is 100% ready to be assembled. and the head is 10 mins work away from being ready to fit. Only thing i would do different if I was to finish the project is go turbo not blown. Put it in the for sale section with all the details and price,then take it from there. Report
December 4, 200718 yr comment_212990 Its all been dummied and all is good, Cam and head are still at my old work. its now 1600cc. If it's got the same crank, rods and pistons as a 4A-GE, wouldn't it be 1587cc exactly like a 4A-GE? And that being the case, what would have prompted you to do it in the first place? Sorry, I'm not trying to bag on your project, but it seems odd that you'd go to all this trouble to make 5K the same capacity as a 4A-GE, without the benefits of DOHC or the 4A-GE's inherent strength. That being said, at least it's something different. VERY, VERY different. Report
