August 18, 20233 yr comment_736097 Been knocking around the Forum for a few years now since joining to discuss my KE20 4AGE engine version that some of the older members may remember. Well believe it or not I eventually had a fast road spec engine built here in the UK by Macer Sports. With the engine I swapped out the 4 speed gearbox for a late T50 5 speed. Having great problems here in the UK sourcing a propshaft sleeve to fit the T50 output shaft. I am now looking farther afield as i need 21/22 spline fitting as my T40 had a 19/20 spline output shaft. Does anyone have a spare or know where I can source this part? Thanks in advance folks. PS here are a few pics of my progress after about 5 years! Report
August 19, 20233 yr comment_736099 Great to hear you have had progress. Have you decided which diff you are going to use? If you are planning on using a 6.7 inch Toyota diff centre, you may want to consider sourcing an entire propshaft so you have the correct fitting at each end. There is a solid AE86 scene in Ireland/UK with a number of people regularly breaking cars. Mind you they are apparently all gold plated. Try https://www.facebook.com/groups/410002902532014/ In Australia these days I would get one from Yahoo Japan, but the shipping for you would likely make gold plated Irish parts cost effective. There is a markup in Australia also as our AE86's came with the smaller 6.38 inch diff, so anyone going with 6.7 inch diff for the LSD needs to find the rear half of a TE72 tailshaft - not common here. All the UK AE86's will be 6.7 inch from factory. But bear in mind the Irish/UK guys import a lot of cars from Japan, and some of the Japanese models also had 6.38 inch rear ends, so don't get caught there. But the gearbox yoke should be common. Here are a couple on yahoo now. Use google translate https://page.auctions.yahoo.co.jp/jp/auction/n1101870855 https://page.auctions.yahoo.co.jp/jp/auction/v1102584509 Edited August 19, 20233 yr by parrot Report
August 26, 20233 yr Author comment_736113 Quote Hi Pete, Thanks for your feedback. Iam going to tempt fate in the short term and will keep my KE20 diff and will just modify the front end and get it shortened. I have a KE30 diff that I am told is a little 'stronger than the KE20. As you say, the AE86 diff is so hard to find but I have had a couple of promises from guys in Ireland so keeping my fingers crossed. Really want to get the car on the road now to get some use out of it. Report
August 27, 20233 yr comment_736115 Issue with the AE86 rear end is its width, and being coil sprung. It will need to be cut down and converted to leaves. TE27 diff housings and axles come up often enough on yahoo Japan. I have a spare set of axles waiting for me to pickup from my local buying agent right now as I’m tossing up putting one in the KE15 anyway, and I have a couple of housings. The 6.7 inch T series AE86 LSD centres fit straight into these housings, and if you get the early ‘Zenki’ diff centre, the TE27 axles will too. AE86 GT rear axles have a wider bearing so probably won’t fit the TE27 housing. Anyway, something to think about. There must be part importers in the UK specialising in buying and shipping parts from yahoo Japan. Report
May 24, 20242 yr Author comment_736700 Well, not much progress since last August due to loads of family stuff that has been going on. i did find that my KE20 propshaft was not considered to be strong enough and the T50 output shaft spline configuration is different to that of the T40 that i took out. I now have the correct yolk for the output shaft to be fitted to the new propshaft that i am having built. Need a few more odds an ends but hoping to get it running by the end of this year, hopefully not famous last words. Report
May 26, 20242 yr comment_736704 As long as you are having fun! I have had a solid stream of 'family stuff' delay me for years..... But if I wander out into the garage, I get all warm and fuzzy inside. My kids laugh at me, but I'm happy, and now I'm finally gettiung somewhere. Don't stress, you will get there. Report
May 13May 13 Author comment_738576 Thought I would ressurect this post as after a house move I am back working on my 4AGE into KE20 conversion. I have a questions if anyone can help. Firstly I am running a twin carb fuelling setup with distributer less ignition controlled by a trigger wheel tps, coil pack and Megajolt ECU for ignition only no complicated MAF gear. I have a kit that is supplied by Trigger Wheels here in the UK, but unfortunately information on how to fit is limited in the UK. I know how the kit works and the basics of what goes where and the wiring but lack knowledge of the best way to position the TPS so that it sits correctly in front of the trigger wheel. Where would be the most sensible location for the coil pack location, also have a support bracket for this but no info on the location. I also have a bracket for the TPS. Will post some photos of the brackets shortly. Report
May 14May 14 comment_738578 Hi Keith, By TPS, are You referring to the throttle position sensor ? Maybe TPS refers to Trigger Position Sensor ? Once You post some pics of these items, you've sourced for your build, it will become a little clearer, & we can assist you. I'll have a look at Triggers Wheels, in the UK, if they have a website, & see if I can see what you've acquired. Trigger Wheels UK Cheers Banjo Edited May 14May 14 by Banjo Report
