finke70 Posted September 11 Report Share Posted September 11 The car came with a disassembled k50 box. I want to assemble the gearbox, i think i have all the parts does anyone have manual in pdf? or assemble video. even pictures ? Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 12 Report Share Posted September 12 Have you got this? That's the only data I have on them. They die because the layshaft bearings are un-obtainable, the rollers were a custom Toyota part apparently. The worn rollers eat into the layshaft and chew off the hardening. You can have another dismantled one for $50 +postage, its sitting in my workshop. Worked fine until I asked a gearbox shop to put in a new front seal and they stripped it, cleaned it and told me it needed new bearings.. I was not happy! Quote Link to comment Share on other sites More sharing options...
finke70 Posted September 12 Author Report Share Posted September 12 1 hour ago, altezzaclub said: Have you got this? That's the only data I have on them. They die because the layshaft bearings are un-obtainable, the rollers were a custom Toyota part apparently. The worn rollers eat into the layshaft and chew off the hardening. You can have another dismantled one for $50 +postage, its sitting in my workshop. Worked fine until I asked a gearbox shop to put in a new front seal and they stripped it, cleaned it and told me it needed new bearings.. I was not happy! Yes, i have some Part catalog pictures. I think i don't have roller , what it looks like? Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 13 Report Share Posted September 13 They are the bearings marked in red on that picture. They are a set of rollers held in a loose cage, and run directly on the shaft, not in their own housing. Quote Link to comment Share on other sites More sharing options...
finke70 Posted September 13 Author Report Share Posted September 13 Yes i have all of Then on "ok" condition. I have to get Main bearings. I don't have little ball 33355a it IS important? Quote Link to comment Share on other sites More sharing options...
parrot Posted September 13 Report Share Posted September 13 (edited) The KE70 K50 rebuild is detailed in the T18 Chassis repair manual Pub No. 36018E They come up on ebay from time to time. Yes you do need the ball, and I've got to say (politely) if you are not aware of that you probably should be leaving the rebuild to a professional. Edit, actually this manual should also be the one. Pub No. 98389. There are a few on ebay if you search Corolla chassis under Service & Repair manuals https://www.ebay.com.au/itm/304943368881?hash=item47000a8ab1:g:-74AAOSwPfhkY~jF&amdata=enc%3AAQAIAAAA4K%2FPo2bVhnBhnrhFv%2FW%2BhsUumxZXJRHHPZ9MxPR6ax6WQDZbusKRCZ064gUZpQrxpvvx5w%2FOw3oQErLWTCP6qGFt7rJdd30%2B8wnRNUxQy8gvqcej4lc8o7W3KosOnbPCb7khFCkfzf3tdBqdKOtwAYhV1A%2FQxZPAPDGOqufkWO%2B%2Fu7CoYRllmURB2Q1RIRv4zbIhCKU5wODYHS%2Fy2CGzFo2lRycsGNjcr7uL7tt%2Fq0X%2BEYVu0%2FqUtDsS7VzJsfmwHGA2HRRPCRJ2wtdW0pRGvAtlM%2FxEcLgo9v6UTpvfRyHV|tkp%3ABk9SR96cvPDRYg Edited September 13 by parrot Quote Link to comment Share on other sites More sharing options...
finke70 Posted September 14 Author Report Share Posted September 14 Allright, maybe i order some manual on eBay even shipping takes few months. I found ball and Main bearings they Cost 60€ and 40€. And yes i should Leaving assembly to professional, but this box was "free" and i just wanted to see If i get box assembled. It cannot Be hard Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 14 Report Share Posted September 14 You KNOW what that manual is going to have as instructions! "To re-assemble the gearbox: Assembly is the reverse of dismantling the gearbox" Which it never is! Quote Link to comment Share on other sites More sharing options...
finke70 Posted September 14 Author Report Share Posted September 14 Maybe. It would also have helped if I had disassembled myself The box. Thankfully that is not My only gearbox Quote Link to comment Share on other sites More sharing options...
