September 29, 20242 yr comment_737008 Hi everybody, I can't seem to find an answer to my question , its an 81 ke So the problem is have is the after market steering wheel adapter is stuck on the column, does anyone have any idea how to remove this , I have the center nut loose ,hope it not something stupid , what am I missing here ? Report
September 29, 20242 yr comment_737010 They often do stick on. Put the steering wheel back on and hit it with both hands up towards you, leave the loose nut on to stop it flying off and hitting you. If you've done that and its stuck, its time for a bearing puller. Report
September 30, 20242 yr Author comment_737014 yeah i tired that and it.didn't work , only want to change the full beam switch , also tried a cheap puller and the puller actually failed , Report
September 30, 20242 yr comment_737015 Hi James, I've had issues getting them off previously, but the technique Altezzaclub has suggested, & You have tried, always works for me. I would suggest removing the nut, & squirting some WD40 or similar, down the splines on the shaft. Leave overnight, or even give them a second squirt. It will come. They are reasonably fine splines, & slightly tapered, resulting in them jamming, when the nut is tightened up. A tapered spline, sometimes needs a sudden jolt to free it. If still no go, get a bit of square timber, & place it behind the plastic boss of the steering wheel, & a few taps with a mallet, from the underside/ backside, will get it off. Cheers Banjo Edited September 30, 20242 yr by Banjo Report
September 30, 20242 yr Author comment_737016 I'll try the wd40/wooden block and see what happens , I took a afew off before on other cars but this 1 is so stuck , I thought I might have missed a hidden nut or something Report
September 30, 20242 yr Author comment_737018 so after breaking a puller and got another 1, i got if off , thanks everybody for your help ,incase anybody else has the same issue , i tightened the puller and left it with tension for a min and kept doing this and for afew turns and pop , off it came full beam is now working but the horn isnt but ill sort that handy enough , Report
