July 29, 200620 yr comment_131131 hey, just a quick question. The tension know on you handbrake, (In my case KE30), Is it needed?? I just got home, yanked up the handbrake and the knob flew off at me. Is it needed?? Can i still use the car?? Will the handbrake fail next time i use it?? Report
July 30, 200620 yr Author comment_131294 I ment the little twist knob at the back, right end of the handbrake. When i pulled it up the knob flew off at me. I went to the wreckers today and it seems that the knob just unscrews so i justswapped it over for a good one. Oh, BuGGAr. Just remembered, i forgot to pay. Report
July 31, 200620 yr comment_131465 ah dude, thats the lock knob. there should be a seperate nut underneath that, ie the nut is against the hanbrake and the plastic knob secures against the nut. and also a washer under the nut to stop the nut savaging the handbrake mounting pad. Is it needed?? yes else the cable wont be connceted to your handbrake lever Can i still use the car?? of course but you wont have a handbrake Will the handbrake fail next time i use it?? lol you wont have a handbrake, just a loose lever. Edited July 31, 200620 yr by irokin Report
