August 2, 200620 yr comment_132052 I wanna put the carb from my Panel Van into the KE25. I know you have to blank off the fuel solenoid to change it over, but then I read that Superjamie grinds the end off the fuel solenoid and sticks a bolt in it. Do you have to cut a new thread or do you have to just replace the whole solenoid or do you grind the end off the solenoid and put a bolt in it and just put the whole solenoid back in? Edited August 2, 200620 yr by Raven Report
August 2, 200620 yr comment_132059 If its the one that stops the engine running on after it is switched off, hook it up so it is triggered by the ignition. No need to stuff around. Report
August 2, 200620 yr comment_132077 coil +ve. have a look at some of the earlier carbs. they have a plug (bolt type thing) in place of the solenoid, which is easily changed over. Report
August 2, 200620 yr Author comment_132079 No worries! Thanks for that. I'll give it a whirl tomorrow and see how i go. Wish me luck haha. Report
