ok i got autotecnica seats yesterday i was goin to put them till i realise my rails wont cross over(piece of s**t)and autotechnica don't make the rail that will work for my car.what have other people used, suggestions welcome.
You will probably have to get them modified onto the original rails?
the oridinal rails get bolted on to the side of the seat these new seats get bolted on from underneith and if you cut weld or bend the rail engineers report is needed.
Exactly my point, If you want them to fit you will have to get them modified on. Being a non-factory Item, I'd assume you would have to get them blue-plated anyway..
i wasnt goin till i have finished the whole conversion. I'm getting a universal rail thing on monday or tuesday, see how that goes :(
Edited by too quick
what about having a look around a wreckers for some that at pretty close?
i put a aftermarket seat in my ke70, i used the stock rails. but then i bolted my rails to my seat they no longer lined up with the floor holes. the solution, i got the trusty drill and a big drill bit and majorly slopped the holes out (and put a masive washer there to pread the load). although this is probaly illegal? it worked, without having to get the welder out.
they are good in some ways bad in others.
good points:if it engineered you know you've done an ok job
bad points:you must get one first!!!
get some universal rails on tuesday that will need hacking up.i got my passenger seat in my drivers side so it can be driven again yay but now i have no passenger seat DEFECT!!!
lol i was gona do that but that but i need my last point, allready on good driving behavior crap.
