September 1, 200620 yr comment_138228 Could someone please tell me where the diff oil drain plug is on a Ke35, I know it might seem like a silly question, but I have been crawling around looking but I can't find it anywhere. I have included an image below of the diff. I have a toyota manual but the diff on my Corolla isn't the same as in the manual... or atleast doesn't look the same. Cheers. Edit> I can't seem to attach an image. But if anyone knows where the plug is, that would be great. Edited September 1, 200620 yr by Widowmaker Report
September 1, 200620 yr comment_138240 If it's a Borg Warner diff, it may not have one from memory. If it doesn't, take off the backing plate, and all the oil will fall out. Apply Silastic, bolt back on, fill with fresh oil. :D Report
September 1, 200620 yr Author comment_138246 Finally got a picture up. It must be a Borg Warner, I've looked everywhere and can't find a plug. Thanks for the help. Edited October 26, 200619 yr by Widowmaker Report
September 1, 200620 yr comment_138247 Yes, I've only used Japs too, hence I was working from memory. :D Widowmaker, yep, Borg Warner. Use above instructions. :D Edited September 1, 200620 yr by Redwarf Report
September 1, 200620 yr comment_138307 I recomend a new gasket that one looks like its leaking pretty bad. :thumbsup: Report
September 1, 200620 yr comment_138346 Obviously once he pulls the backing plate off to drain the oil, he will need a new gasket (or some form of sealant) I've done 4 million diffs, and never once used a gasket, Ultra Blue is your friend Report
September 1, 200620 yr comment_138378 Obviously once he pulls the backing plate off to drain the oil, he will need a new gasket (or some form of sealant) I've done 4 million diffs, and never once used a gasket, Ultra Blue is your friend Amen to that. Just make sure you cure it first. Report
