Is it possible to get vented discs for the RA40 celica struts?
I've checked the DBA catalogue online and it only lists them as solid discs....
Whats the widths of the solid rotors? I doubt you'd be able to fit venteds in your calipers. SR20 vented brakes are 26mm thick and my skyline vented brakes are 32mm thick.
RA40 are non vented. You can get slotted for them. I ran them on my old trueno. Slotted with Bendix Metals. No brake fade coming down Mt Gravatt Lookout. If you want to run vented on RA40 you need to look at running Ra60 setup. There is a way to do this on your RA40 struts apparently but I never tried it.
Craig
Just purchased some RA60 struts complete with LCA's castor rods, calipers and discs today, so I'm going the vented route :D
