Just things like brake upgrades, handling products, cams, injectors, heads, ecu pissies, diffs etc etc tec. Online shop link would be great. I'm really after a rear strut brace atm if they exist. Can anyone piont me where to go?
For an ea82 with 4age guts
Edited by BiGGy
Front & rear strut braces to suit the AE82 are available at tonnes of places.
Good luck on brake upgrades, twincam AE82 brakes are about your only known upgrade, aside from possibly AE101/111.
Basically you need to use the tools that Google has provided and SEARCH THE WEB!!!
Rolin Automotive-Jap Parts-Japanese Used Import Car Parts - http://www.japparts.com.au/
Asian Auto Spares - http://asianautospares.com.au/
Japwreck Recycling - http://www.japwreck.com.au/
Performance Wholesale - http://www.performancewholesale.com.au/
AutoBarn - http://www.autobarn.com.au/
Stewart Wilkins Motorsport - http://www.swmotorsport.com.au/
Blackwoods - http://www2.blackwoods.com.au/Default.aspx
Wade Cams Australia - http://www.wadecams.com/
http://google.com.au
http://altavista.com.au
Made my own rear strut brace.
Brakes - ae9x, ae1xx
Disc Brakes Australia
http://www.dba.com.au/default.asp
thanks for all the links, ill check them out. I was planning to make it up but the thread on the towers are so small, no more room for plate. How did you do it? different model? got pics? cheers again
The brace is 25x1mm square tube.
While the mounts are made from 50x25x3mm rectangle tube cut down to size.
The motors going through a rebuild at the moment.
If you don't know it here's a link on TwinCam.com for AE92 & AE82 Brake upgrade options....
Thanks for the pics, looks like a good job, but you see what I mean with the thread? the nuts are flush with the thread without the plate weakening the nuts with the plate by taking couple of threads away. There isnt much upwards force so I guess this would be ok. how thick is the plate? 1mil? Thanks for the brake link also I didnt know about it.
2mm thick. Its not a plate but, 50x25x2mm rectangle tube cut down to size.
In the pics i said it was 50x25x3mm, it should have been 50x25x2mm.
Yeah i know what you ment with the threads but i wasn't overally worried with it cause the bolts cushed into the metal and formed it a little.
