Leaderboard
Popular Content
Showing content with the highest reputation on 03/05/20 in all areas
  1. With the cage back in the dash could be re-fitted, and I started on the Terratrip wiring again. This was all fine and we had bench-tested the new probes 6months back, but it wouldn't count! Turns out the probes are directional in wiring, a +ve and -ve so to speak, and I had, by luck, got both of them round the wrong way! That's all tidied up and working now, but before then we thought we'd try the Terratrip unit in Mao, where it had been used before we fitted a new connector on it. Of course modern connectors are for very small wires.. so we might have to go over Mao's wiring again.. Now, some people believe that you can tie a nail onto a piece of string and drop it down a length of poly hose, then pull an electric fence wire through, so you can lay it on the ground between fences at gates... When this didn't work we did try blasting it through with the 12V air compressor & a tissue. It worked 'in the lab' for 2M, but when we were out with a 70M length of poly and straight in with the fence wire it didn't work at all! Damm, another great idea down the drain! So, time to head home.. Now, what could this road "worker" be doing?? He used to hold a lollipop and turn it around as soon as the opposing traffic had come through the road works... Now he sits here watching the cars as the new traffic lights hold us up for AGES after the opposing cars have gone, as they're on a timer! A lot of people need to be fired if Australia is ever going to get more efficient!! This fascination with OSHA and safety could handle a big wind-back too!
