Leaderboard
Popular Content
Showing content with the highest reputation on 05/21/20 in all areas
  1. Hi Bayley, If your car has a "ballast" resistor attached next to the ignition coil, short it out with a piece of wire, from one terminal to the other. Try starting your car again. If it runs this time, when you let the key spring back, then your ballast resistor has burnt out, or gone open circuit, & will need replacing. If that fixes it, it is an easy fix. If it doesn't fix it, then give us a yell, & we'll try something else. Do not run this for anymore than a few seconds, as this technique may try to keep the starter motor turning, depending on how the wiring is currently connected. Cheers Banjo
