Leaderboard
Popular Content
Showing content with the highest reputation on 04/19/23 in all areas
  1. Yep, that is a problem area, many Rollaclub members have experienced. This post explains the issue & ways to fix it. https://www.rollaclub.com/board/topic/82146-new-to-rollaclub/?do=findComment&comment=731487 It is imperative that before you fit the mainifolds, that both exhaust & inlet manifold faces, that bolt up to the head, are alreeady in line. Check with a straight edge, before fitting. The one piece gasket is also a must. This thread might assist your understanding of the manifold issue. https://www.rollaclub.com/board/topic/74148-one-piece-manifold-gasket-k-series/#comment-715486 Unfortunately, it will require you to drop the exhaust pipe, & extract manifolds & carby, & start again. Cheers Banjo
