Leaderboard
Popular Content
Showing content with the highest reputation on 01/08/25 in all areas
  1. I found a DC motor speed controller on ebay, which controls the electric water pump, & flow of the coolant, from a trickle to full on. It handles a DC load of up to 10 amperes. With the radiator cap removed, you can clearly see the water flow change as the water pump speed is changed. It has a knob on it, which will be useful, as I manually try different flows & resultant temperatures, but also can be controlled by a 0-5V DC voltage, ultimately; from a controller, once a control system & program, is determined. So I started fitting sensors to the coolant system in several spots today. One on the hose leading to the top of the radiator, which will basically measure the temperature of coolant leaving the engine head, & entering the radiator. I already have a return line, at the back of the head, which returns hot coolant to the thermostat housing. I will fit one to that pipework, close to the rear exit from the head. Another will be fitted at the water pump, which is attached to the lower outlet from the raidator. This will allow easy delta T across the radiator, by sunbtracting radiator outlet temperature from radiator entry coolant temperature. The other place, I would like to measure coolant temperature, is inside the block coolant passages. The most convenient way to accomplish that, is to tap a temperature sensor, into a Welsh plug on the side of the block. It's simply a matter of drilling a hole & tapping it, in a Welsh plug, & then replacing an existing one. That will require the manifolds to be removed, to gain access to the three (3) off Welsh plugs on a K Series engine. So almost there, & should be soon starting the fun bit; which will be determining times & control program, to get the very best coolant temperature control. Cheers Banjo
