Leaderboard
Popular Content
Showing content with the highest reputation on 02/28/25 in all areas
  1. I'm using BCRacing coilovers from Justjap in Sydney, recently fitted them to my KE70. You cut the strut leg near the bottom and weld the coilovers onto it. so you get the large diameter shock tube with a stock hub. https://www.rollaclub.com/board/topic/42407-the-girls-ke70/page/16/#comments You might get weld-on adjustable spring bases too, but then you're limited to the stock tube diameter. Cheapest is to cut the spring base off and weld it back on 20mm lower.. but you're still stuck with the same diameter strut tube and hence crappy shock options.
