Everything posted by Drift_Marti
Struts Interchangeable ?
ok tops did change over, but the shocks were wrong, the 2 camber bolts that bolt to the nuckle were to small as was the opening, the strut its self was way to thin aswell
What Seats Will Fit Into An Ae82 Twin Cam
ok which seats are the closest i don't mind welding a small peice of flat bar on and drilling a hole
ʞ©$ɟ, ok well looks like rails it is.Will ae82 single cam seats fit into an ae82 twin cam ?
i don't really want to use after market seats, i want to know what seats will bolt in from other toyota modles,I'm asking for interchangabillity
so your saying nothing from the toyota range will bollt in, not even an ae92 ?
I'm in perth western australia, i would like something with a little more support that will just bolt in from another toyota
I have searched but can not find the answers i need i have an ae82 twin cam corolla and my drivers seat has had it, I'm wondering what (in the toyota range) is an direct bolt in and is easy to find ? i only really need the drivers seat but if i could find a pair of seats and rears then I'm happy too grab them. I just need to know what will bolt in with no modification thanks Marti
the rears are alot longer than the fronts, ok so i can change the 4 stud strut tops over no worries ?
I have just bought a set of ae82 struts(i have a twin cam ae82) the struts i got only have 3 bolts on the top hats, front have 3 only and rears only have 3.Where as my ae82 has 4 my question is the rear struts are fairly long, will they fit being 3 bolt 2nd question is can i used the strut tops of my ae82(4 stud) and swap them to the new struts with out any hassle thanks for your help Marti
Ecu Upgrade
if you have basic mods like air filter and exhaust just get an apexi safc or some other form of air fuel correction
Window Reg And Ps Pump Interchangeability
Iv sent Yiu an email
Any body ?
I own An ae82 4age corolla(fwd) I need to find a drivers side window regulator with handle and I need a power steering pump and lines. I'm wondering what toyota models have these interchangeable parts eg 1990 seca ? I'm findin parts very hard to find Any info would be great Thanks Marti
Ae82 4Age Corolla Window Regulator And Winder Handle
as above i need the drivers side window regulator and handle for an ae82 4age corolla I'm not sure which types are interchangable pm me if you have anything thanks Marti
Ecu Diagram Ae82 4Age Big Port
Yea that would help please email them to me at [email protected] Thanks heaps
Hard to get to?,what has to be removed to get to it
Ok I know it sounds stupid but where is the computer located I'm only used to nissans ha ha
I need an ecu pin out diagram for an ae82 4age big port.I need to know where the o2 sensor signal wire is so I can splice into it to ran an af gauge Thanks for the help Marti
Speedo Stopped Working
yeah it is 2 peice and getting behind the dash is easy the cable is actually seased
Ok well if I can't find the cable here in Perth. Then I'll grab yours
No worries I'll phone around on Monday you wouldn't happen to have a 4age big port harmonic balancer in good condition aswell would you ?
I don't have small hands. But the hard thing will be feeding it threw because I have big hands how long will it take for it to get to me.pm me your bank details and I'll send the money threw now
Yeah just checked the cable and it's very hard to turn.I live in Perth how much would you want for the cable plus shipping to me in Perth. So I just take the cluster out disconnect it from the gear Box and put the new or in ?
Do they just brake?.I'm about to pull I'll out from the box and have a look are theyexpensive or hard to replace ?
