Everything posted by HayzTawil
T-Series Diff In Ke30
hello peoples just fitted a t series diff out of a ta22 i think, well pretty sure anyway into my ke30 2dr, i have previously fitted a ke55 tailshaft, huge compared to a ke30 tailshaft anyhow after fitting the diff i realised the tailshaft needed to be shortened because the t series center is longer (SPEWIN) so getting it shortened tomorrow for $120. don't know why this happened, i thought all u have to do is swap brackets, mounts etc?? any1 come acrosss this issue?
Ke30Diff
hi i need a diff to fit my ke30 it need to be strong enough for 4age 20v please some1 help can't seem to find any1 in vic area who can modify :bash: any1 knows any1 or any1 has something like that for sale? thanks guys!!!!
20V Stacks Or Trumpets + Filters
anyone know what the best size trumpets to use on a 20vST and where i van buy from vic area melbourne, shepparton anywhere?? anyone have some for sale?? keeping in mind i have about 90atw, if that makes a difference in trumpet size, thanks peeps!
Ta22 Rear Disk Conversion
ive heard of people using r31 discs on t series diffs, ill prob do the same thing but ofcourse needs a bit of work to fit.
Engineers Certificate Ke30 20V 4Age
hopefully the small section i cut out and pushed back in the firewall will be ok :blush:
finally got the rolla booked with an engineer next monday so holding off everything, diff front brakes etc, he told me he is gonna go over the whole car and then give me a list of what to do hmmm should be interesting :))
Supercharging A 4Age 20V Silvertop
what about turbo charging most likely a garrett t3/t4 or t4? same issues or...? i already have after market ecu cost me bout 3500 it has 90atw my mechanic says to leave internals for now, whats a better option supercharged or turbocharged?
ok thanks trev, what about the sc12 then I'm currently bidding on one on ebay, don't wanna get it if it doesnt work properly on 20v. i read somewhere that the silvertop has some same internals though as the gze?
or sc12? or is that the same as sc14?
ok so so a sc14 is out of the question?? whats the safest boost for stock internals?
hey guys I'm thinking of using a 4agze supercharger on my 20v ST, has this been done before? are the internals strong enough??
Ke With Typical 20v
also whats the best trumpets to use? or are they the same?
Ke With Typical 20v
[quote name='altezzaclub' You will probably get a better motor with more torque by running a 7psi turbo with bigger injectors & a computer. what size injectors do u suggest?
Ke With Typical 20v
yeah was looking at changing the cams aswell, so what your saying is to get a bt head instead of just the bt throttles? why do u need to get rid of the vvt if over 272kw unless i misunderstood? i most likely will be turboing it what needs to be done to internals other than valve springs? with the trumpets, do they have to be inside a airbox? ive spent alot on this motor already so i wanna do it right all the way. thanks for the input guys!!
Ke30 Diff Upgrade
will the r31 diff be strong enough for a turbo setup?
Ke30 Front Break Upgrade
I'm sure ill be right buddy tc
cheers rob, and cuzzo i was half asleep when i posted this lol didnt even notice till now thanks champ your a good bloke. p.s get cocky on someone elses thread buddy don't waste my time!!
hello again just wondering if anyone knows of someone who actually builds up front brake upgrades for ke30? i used to have a number of this bloke in footscray vic but lost it can anyone help please....
Ke30 Diff Upgrade
thanks fellow members your help is appreciated!
Ke30 Diff Upgrade
ok so i done some research i came up with either a 98 to 01 hilux diff or a skyline r31 diff which apparentely has the same stud pattern as a ke30 can any1 confirm?
Ke30 Diff Upgrade
hey peeps wus happening, i have a 2dr ke30 worked 20v it has almost 100kw atw ive blown a banjo and jus yesterday i blew a borg warner I'm currently fitting in a ta22 diff or T series and somehow doubt it will last what is the best option hilux skyline etc etc any sort of in put would be good better yet if anyone has a diff for sale plz let me know via this thread 0r pm cheers boyz n gals!
Ke With Typical 20v
hey mate i have the same project just got it on the road i have custom extactors 2inch exhaust autronics ecu on the dyno it made 90kw atw awsome power, i raced my mates VL turbo i was ahead in 1st 2nd and 3rd gear, next thing i might do is lighten the fly wheel and bolt on black top throttles as the are a few mm bigger. eventually i will be doing a turbo set up aiming to get about 200 to 250 atw.
My Dirty 30
hey bro what you do with interior?
20v Silvertop 4age Into A Ke30 2dr
thanks guys apreciate it!! down the track i will be using a turbo what is a suitible diff? and what kind of turbo is good to use on this engin? don't know any1 that builds break upgrades i spoke to one bloke he said he can do it for 700 but i lost all his details
hi evry1 i have installed a 4age 20v in my ke30 i have a ta22 diff which is yet to go in is this enough for an engineers?? also what can i do for front brake upgrade just looking for somethng not so complicated money is not too much of an issue, thanks! one more thing is the ta22 diff strong enough for the 20v silvertop?? ive read some threads on the issue but still not too sure any input would be much appreciated!!!
