Everything posted by jonh ke11
Best Front Brake Setup For Ke11
Hi I tried ae86 p/steering arms did not work ball joint on ke11 was to small any help thanks
How about a van brake pedal setup with booster and master cylinder inside has anyone done this before
I have a ke11 with drum brakes all round what would be the best brake setup for the front. I'm building it for a 4agte
Ke11 4Agte
Hi did you use ke20 struts with ke55 disc and caliper and what diff you going with I'm doing same conversion
Ke11 Diff
How much would it cost to shorten a hilux diff
Ke11 Diff
How strong is the rx3 diff would it handle 4age turbo
Ke11 Diff
How about a rx7 s2 diff with different off set rims?
Ke11 Diff
Just wondering what diff upgrades for a ke11 diff is there or a diff replacement with minor mod like moving mounts around without shorting a diff
Blue Slip??????
I do blue slips it's fine
Ke11 4Age Engine Mounts
On eBay so do they fit
4AGE ENGINE (RWD) MOUNTS MODIFED TO SUIT TOYOTA KE20 would this work on a ke11 thanks
New Window Reg Ke11
Is their any new window reg for a ke11 or can I use one off a different model thanks
Have you got some that I can copy from
need some find whats the best way to get a 4age into a ke11
Ke11 4Age
can i put a ae71 complete cross member cut it down to fit a ke11 engine bay with a rack n pion setup has anyone done such a conversion?
Davros' Ke10 4age Project
good work on our car what did u do about your steering problem hit clutch slave cylinder
4Age Into Ke11
hi sorry new to this does anybody selling custom made engine mounts to fit 4age into a ke11 and i need t50 gearbox thanks
I'm going to do same project on a ke11 were can i get some engine mounts for 4age convertion ordo you have the specs for the mounts so i can make myself thanks
