to jack front putt the hydrolic jack straight under the back of the tow mount in photo 2 tthen put the jack stands under the chassis (once jacked up look in behind the front wheels looking across the car there should be two rectangle shaped bits of metal running down the car bout 30cm in from the seal panel on each side)once the stands are under there pull your jack out of the way for easy quick oil change and to do the back put that jack under the bump seen in photo 3 (in the middle) then in photo 4 past where you are pointing in on the chassis put th jack stand in there!
