ke70trent
Everything posted by ke70trent
  1. are your rear shoes low on pad material?like 2-3 mm or metal on metal? or the inside of the drum badly scored?
  2. for every litre of petrol used one litre of h2o will come out the exhaust as gas but as the exhaust is still cold some of this will condense and come out as liquid! :)
  3. to jack front putt the hydrolic jack straight under the back of the tow mount in photo 2 tthen put the jack stands under the chassis (once jacked up look in behind the front wheels looking across the car there should be two rectangle shaped bits of metal running down the car bout 30cm in from the seal panel on each side)once the stands are under there pull your jack out of the way for easy quick oil change and to do the back put that jack under the bump seen in photo 3 (in the middle) then in photo 4 past where you are pointing in on the chassis put th jack stand in there!
  4. so i've just got myself a ae90 hatch and I'm having trouble working out what engine is actaully in it! thought some one out there might have a better idea! so on the vin plate it has 6-AF (the 1.4 DOCH) But in the engine it has a sticker saying "4A 3m/t"? and on the rego paper it has for the engine no. 4A9144979 so with a quick bit of research (wiki) i think it is a 4AF DOHC 16v? as the photo is the exact same setup on top to look at! but the 4Af never came out in a car in australia! so i've got no idea whats going on! other then possable jap import engine? but who would import a carbie 4A engine?
  5. i want two of the 50x5cm ones how do pay/postage?
