November 10, 201114 yr comment_565507 Hey guys On my 1998 corolla hatchback the left rear brake is squeaking when driving slow and goes away when I hit about 50km/h When it happens if I put the handbrake up just a tiny bit (not enough to turn light on) it goes away Also if I pull the handbrake right up just before it locks the wheels it's extremely loud abd squeaky I'm not sure what is causing this but it's becoming quite annoying hopefully someone knows what I can do Thanks Report
November 10, 201114 yr comment_565521 How'd you notice it in the first place eyy? Pulling handbreakies? ;) Kidding haha. Probs need to replace your pads/drums/rotors Report
November 10, 201114 yr Author comment_565548 Hey I drove through some gravel and it started after that , And rear brakes are drum Report
November 11, 201114 yr comment_565623 Pull the drum off and clean it out, will be excess dust in there. Report
November 11, 201114 yr Author comment_565683 Okay cool do I just take wheel off abd take drum off and clean it with air or something similiar? Report
November 11, 201114 yr comment_565686 You will cop a lungful of dust and choke if you just spray the brakes with air. Spray brake/parts cleaner and once its good and wet you can air dry it. Report
November 11, 201114 yr Author comment_565689 Okay thanks, it's my first car so I don't know what I'm doing but I'll give it a go Report
November 12, 201114 yr Author comment_565717 I cleaned out the drum and it ain't squeaking anymore, let's hope it stays that way, thanks for all your help guys you saved me a bit of money :) Report
February 6, 201214 yr comment_582621 are your rear shoes low on pad material?like 2-3 mm or metal on metal? or the inside of the drum badly scored? Report
February 6, 201214 yr comment_582631 a trick we use at work spray brake cleaner wait for it to dry and use 80grit sand paper and give it a good sand both drums and shoes. hope it helps goodluck :) Report
