speng g6r
    5
Everything posted by speng g6r
  1. Yes it will, all 4a use the same bolt up pattern the c160 box that comes on levin bzr is what toyota use in corolla g6r uk spec on a 4afe engine. I now got that box bolt onto a 4age 16v.
  2. I will check it all over again. I forget to mention that I am using the 4afe radiator and fan that stays on once the key is turn to on position this why my battery keep going flat. It doesn't hunt anymore its just cut out once the engine get warm up.
  3. It should bolt up. MY C160 box from a 4afe corolla g6r I am using on 4age tvis bolt up with no problem. 4afe clutch kit it 212mm
  4. want get my 99 corolla g6r tvis set up running for christmas. lol
  5. Hello toyota for life
  6. It will run ok on cold start. Then up and down before. now it just cut out once warm up. I have to keep my foot on the gas pedle to keep engine on once I get it started. It will take a few crank to get it to start. Also I notice it will take a lot of battery life to crank it so battery keep going flat.
  7. Hi you all I new to this site: I have swap out my 4afe motor for a 4age tvis. got the loom splice together by a pro. the problem is the car will start run for 10-15 min then cut out. it seem to be running rich because of the black smoke that comes from exhaust. my temp gauge was working when I first start car up, after a few revs the gauge drop down to cold and remain there ever since. I have change the efi sensor that locate on cylinder head on gearbox side.; still no joy? can some1 please help me with some suggestion on what to do to get this car going properly. thanks
