asirike20
    234
    2
asirike20 last won the day on October 1 2012
asirike20 had the most liked content!
  • Location
    Sri lanka
  • Interests
    Automobile
  • Real Name
    Asiri
Recent Profile Visitors
9741304 profile views
asirike20's Achievements
9
  1. Thankssssss ........ ok then i'll order a pair......
  2. Hi rolla bros, Does anyone here know this company? http://www.newoldcarcompany.com.au/toyota-corolla I need to find a pair of taillights for my ke20. They make brand new ones and i found some on eBay. these looks very fine for me, does anyone here use them? How is the quality ? I'm gonna buy a pair so i'm seeking for your review. Thanks.
  3. no there is no gauges or warning lights other than the typical ke20 cluster........ "contact points" means there is something like a relay's contacts, just like in the headlight switch. I can clearly see it moving up and down when i manually turn the speedometer. I there any over speed warning chime in Ke20s ? One of my friend told me that it is a warning chime, but not sure...
  4. Does anyone know what this contact points do in ke20 speedometer ?? cannot find any clue. There is nothing mentioned in the wiring diagram. Anyone know what this thing does??
  5. Paintwork this time............ Had to remove the paint on roof because of bubbles caused by the underneath surface rust. Repainted with eggshell finish until a full respray.
  6. great work mate........ Keep it up......
  7. Hi guys...... after a long time........... updating........... found original fender mirrors........ polished and fixed.......... And the bumper corners with some heavy rubber stuff.......
  8. Hi mate....... Thumbs up for your restoration............. Keep us updated........... Could you please tell me the exact location of the place where you bought the fender and rear Toyota and Hi deluxe emblems......... I'm searching for these badges from a long time ago.......... Thanks.....
  9. Hi mate, Thanks for your info......... done the same job.......... skimmed off the guide and all doing great........ no more oil burning headache........... :y: :y: :y:
  10. Hi mate, just read your valve stem seal clashing problem. I need your help......... i have the same problem. I have installed new valve guides recently. But they are exactly same in lengths as the original guides. valvetrain is stock but the problem is the valve stem seal gets hit by the valve spring retainers. I cannot figure out what is happening. Is it causing by bad length stem seals??? because the rest is stock......... i didn't buy stem seals separately. They came along with the Head replacement kit named as FUJI (made in japan). :hammer:
  11. Does anyone know what is this valve like thing which connects the distributor vacuum hose???? my Sprinter ke20 has this one but not connected any hose. It has two connections. one side says CARB and the other side says DIST. Any idea what it does??? or how it works????? :hmm:
  12. Oh my god............ such a beautiful condition car.......... need more and more pics maaannnnnnnnnnn.............
  13. wreck yard is in alawwa...... workman is in hiriwadunna area called "Sarath"
  14. i need to replace my timing chain since it seems to be worn. how can i buy a new one? is there any guide to ask from sellers??? any part number / length or number of links of the chain????
  15. is it possible to swap 5K or 7k dizzy straight into my 3k engine ???
