NEO_E70
Everything posted by NEO_E70
  1. Hey guys, In the process of converting my AE71 to flat front. Just wanted to clarify, are the bumper mounts different between slant and flat front bumpers? If so, will standard flat front bumper mounts suit a chrome bumper? Cheers, Matt~
  2. Considering I'm only free to do stuff on weekends I trudged out in the rain and bled the system. Was able to start the car in first with clutch to the floor, didn't jump. Releasing the clutch slowly caused the car to mutter, eventually stall. Checked and double checked lines, no signs of leaks anywhere including footwell. Still with the clutch disengaged it was damn near impossible to put into a gear, reverse simply wouldn't happen, others would need to be somewhat forced in. Am I safe to assume it's the pressure plate? If so I'm looking to buy a decent kit, bear in mind it's a daily driver not a track car. Any suggestions? Looking at: http://www.ebay.com.au/itm/400367458033
  3. Cheers guys, have a bottle of fluid ready to go, just havn't had the time due to work. Will have a go during the week and report back.
  4. Just tried, jumps forward with car in first gear clutch to the floor.
  5. Hey guys, Recently the clutch in my AE71 seems to have given in. Fully depressing the pedal seems to have no effect, unable to put into any gear. Prior to this initiating reverse would give a crunch more often than not which didn't happen at all previously. Fluid levels are within operating ranges. Not sure if worth mentioning but there is a wet patch below my transmission drain plug. Doesn't appear to be any leaks to clutch assembly. Needing advice on where to start before taking it off to my mechanic to have things checked. 84 AE71 4AC [T50 trans] 90% stock
  6. Got my mini-url sticker in white today, quick postage cheers! Next to my keys for reference:
  7. Hi all, Recently purchased a set of these: Now I've done a fair bit of searching and still havn't got a strong idea of how to wire these up. Mounting is straight forward, but if anyone has experience with these particular mirrors it would be muchly appreciated if you could point me in the right direction. After coming across this article: http://www.rollaclub.com/faq/index.php?title=Upgrades:Corona_Power_Mirrors_into_late_KE70/AE71 I've got a basic understanding of how power mirrors are wired in older Toyotas. Now would something like: http://www.ebay.com.au/itm/TOYOTA-AVENSIS-MK1-MIRRORS-CONTROL-SWITCH-84870-05020-98903221000-1998-2003-/290609734407?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43a9b0a307#ht_2680wt_1163 Work as intended? I havn't got the mirrors in the mail yet, but would like to order in a switch ahead of them arriving to speed up things. Thanks for reading, Matt~
