4ke70
  1. Yes it's a one piece shaft And yes I think they did come with a s But I have a two piece ae71 and the bit that bolts to the diff on that looks to be the same as the 1 piece
  2. What do you do with the tail shaft I have the stock ke70 and a ae71 panel van shaft but the bit on the back that bolts to the diff is different And the uni joints look way different I'm bolting up a 71 tail shaft to a ke70 borgy
  3. Hey just wondering what the two plastic bits would be worth that are behing the rear window or if its windowless bit those black plAstic bits if there worth anything cheers
  4. hey guys just s few questions about the dellorto carbs I'm wondering if you can run a supercharger with 2x twin 40mm dellorto carbs and if the carbys them selfs can run facing upright?? any info would be good thanks
  5. anyone no the weight of a ke70 with a 4age in it??
  6. Thanks guys what's a after market on worth??
  7. Hey just wondering if you can double up a ke70 sway bar and if so how you would go by doing it cheers
