superbmobile
    61
Contact Methods
  • Website URL
    http://
  • ICQ
superbmobile's Achievements
  1. spotted a green ke30 near darlington appeared to be sitting on bump stops..
  2. quality degreaser and pressure washer can't go wrong..
  3. Certainly paint it gloss white, matt white looks cheap and horrible.
  4. shouldn't crack if your not going to put any sort of pressure on them mix the bog correctly and grind the paint off the guard for better adhesion and it should be right. Personally i like the un smoothed look so i would just bolt them on.
  5. spotted nice stock white ke10 in town earlier.
  6. lyrical commission/ pegz/ mortar and bias b are all pretty good.
  7. I had 30 thou shaved off my 4k head to raise compression. So i put it all back together today but now there is a really loud tapping that sounds like its coming from the top end its, not valve clearance or the rocker gear because i adjusted the clearances until they almost had no gap at all but it wouldn't go away so i put another rocker gear in and still the same I'm thinking maybe because of the head sitting lower the push rods are on a different angle that makes them noisy but I'm not sure what do you think?
  8. My 4k blew the head gasket so Its a good time to get the head shaved to give it a bit more power how much would you recommend taking off I'm thinking around 20 thou but tell me what you think. :dance:
  9. do you want to spray in acrylic enamel or 2pak? if you want to paint acrylic or enamel you can use an acrylic primer if you want to paint 2pak you have to use the 2pak primer.
  10. nice buy mate.
  11. ok some pics only half painted still due to laziness lack of paint me effort and overall due to my slack ways but here they are. :wink: Door jams R/hand Guard R/hand guard from different angle. Have also paint wiper thing beaver panel and the back of a door. Ill resume painting when i have sufficient funds for more paint.
  12. good to see another quality wagon build :wink:
  13. 20's fail miserably. 15inch is the maximum size that should be used on any type of rwd corolla. 16's are even too big in my opinion.
  14. Go on ae86 driving club and enter the commercial sales section there's a guy on there under the label (AJPS) his names David Lawson he should be able to sort you out.
