Everything posted by HIGH_ROLLA
5K Wont Run Please Help
pump was faulty replaced and started first go
if its not the pump then ill have to go in somewhere with air compressor and check the line to the tank but i doubt its that as theres fuel up to the pump but i guess it could be blocked and not allowing whatever fuel is left in the line to flow
yea cheers for you're help but yea going to try a new pump as i said because i have fuel to pump but not weber and the line isnt blocked but the pump is new and i can't find a fault in it but ill swap it just too see
ok so no fuel to the weber but the pump is only a couple of months old and i can't find any faults in it when taken apart. could there be something before the pump that would not allow it to pump through? like a blockage or dirty filter etc? or do i just replace pump and see if thats it? just want to know if theres anything i can do tonight until i get to a new pump tomorrow cheers
not out of petrol can see it in the filter, opened up pump and also has fuel in it, battery is charged. I'm going to test if fuel is coming out of fuel line after pump or not maybe it isnt getting to the carb and only to pump even tho i recently replaced the pump
hey all got a 5k in my rolla was driven daily every day ran amazing and never had any troubles. havent drove it in over a week and now can't get it running? I'm confused and can't figure it out can get a fire with start ya bastard but wont run any help appreciated
Ke20 5K Conversion Alternator Issues Please Help
yea waiting on a mate to bring it round but from memory its just a single wire not double. soon find out
Hey all hopefully someone can help me out today or tomorrow with some wiring info. The issue is i installed a 5k with 5speed into my ke20 which was 3k auto that i received not hooked up or running. The alternator on the 5k has a 3 prong plug on the back of it and my loom only has a 2 prong plug in it? What do i have to do to hook it up? I've done my research and all the topics I've found the ke20s have 3 prong plugs in their looms not 2 so I'm kinda stumped. Also had a look at my ke10 to see if it was same and could help but that has 3 prong plug in its loom too so not much help. All help is much appreciated as i need this running asap! cheers.
How To Remove And Instal A Pedal Box In A Ke20 Corolla
really? that sucks
^^ Done this and mine still won't budge? The steering column/shaft won't real move down much either its quite tight.
Ke10 Seats
Yea very similar to my ke20 seats Thanks for the feedback
Ke10 Seats
Ke10 Seats
I was told original bucket seats but I doubt it
Ke10 Seats
Ke10 Seats
I just recently received a ke10 corolla and I was wondering if anyone would be able to tell me if my seats were original from factory or not. I don't think they are but I'm curious to find out. The rear seat, all the door trims and the backs Of the front seats are all viynill? And the fronts of the fronts are a soft material. Any info would be great cheers. How can I post a photo on my iPhone?
Ke70 Parts Into Ke20?
yea it was auto so it should fit then? and would it be hard to make the rest fit or just not worth it? not many 20 parts at the moment
can i use everything out of a ke70 and put it in a ke20? I'm talking about parts for a manual conversion so parts such as: -pedle box -gearbox crossmember -clutch, accelerator, etc. cables all info would be much appreciated as I'm probably putting a 4k 4speed in my 20 as it has nothing will it all bolt up? or do i need 20 gear cheers.
4age Into Ke70 / Ae71 Conversion - The Step By Step Noob Guide
if i want to get this engineered can i do the conversion myself and then get it engineered or do i need to take it into a workshop and the engineer does the work? cheers
ok i might get blasted for asking this but i just want to be sure. could i get a ae86 front cut and use the crossmember, engine mounts and pedel box, etc and all the bits will be there or do i need the parts from ae71 instead cheers.
