KE30/KE55 Toyota Corolla 52mm Gauge Holder
I’m excited to officially release a new product I’ve been working on, a Twin 52mm Gauge Holder with 12V Accessory Mount, designed to suit KE30/KE55 Corolla (and other compatible models). Key details: • Made from ASA Carbon Fibre • Heat resistant to ~95–100°C (ideal for Australian conditions) • UV-stable and far more suitable than PETG for interior use • Designed to match factory interior texture as closely as possible • Flush fit using existing factory mounting points I’ve put a lot of time into the design, CAD work, and material selection to make sure this is a durable, clean-looking, and practical solution that actually holds up in real conditions. https://www.coreprintengineering.com.au/products/toyota-corolla-ke30-ke55-twin-gauge-usb-holder?variant=43561969385531
BIGNESS changed their profile photo
KE55 SE Disc Brake converstion
No issue I will most likey refurd the rear drums with fresh parts if possible, I will take photos for you when possible. this was more than enough info thank you so much matey.
G'day guys I'm looking at changing the current drum brakes on my KE55 to a disc brake setup front and rear. any ideas on the best options. DW about price just want a safer and better car for myself on the daily.
