knibusu
Everything posted by knibusu
  1. Hey guys so I had a problem with me KE70, it was leaking fuel from the bottom of the mechanical fuel pump, thought the pump was at its final days, ordered a brand new GOSS Mechanical Fuel Pump, installed it on the 4K, same issue occurring fuel leaking from the same spot. Just wondering if people have had the same or similar issue and things you did to fix it, I thought it might be one of either these things, uneven insulator, did not scrape the old gasket off enough(I pretty much scraped it back to bare metal), just shitty aftermarket gaskets(they were plasticy ), the engine block is no longer flat, or just need to use permatex sealant. Any response will be helpful.
  2. Hey guys I know its been 11 years since last reply, but worth a shot, so my old mechanical fuel pump was leaking from the bottom I believe it was from the bottom of gasket seal, as I could not see any fuel from the holes at the bottom of the pump and it wasnt leaking it was more like pissing, I ordered a brand new Goss Fuel pump with brand new gaskets, Installed on the 4k, and same thing is happening its pissing from the gasket seal, what could be some causes of this uneven insulator, did not scrape the old gasket off enough(I pretty much scraped it back to bare metal), just shitty aftermarket gaskets(they were plasticy ), the engine block is no longer flat, or just need to use permatex sealant. Any response will be helpful.
