dorifto
  1. Thought I'd add my 2c What I think his trying to say is that the wheels are 'too' wide to fit a 195/50 sized tyre on as it will stretch a tad as they're best suited to wheels up to 7 inches wide. However, any Good tyre shop should have zero issues fitting a 195/50 over an 8 inch wheel as it's not that much of a stretch really. I've fit the exact same wheels to the exact same car; here's a photo The tyres are 195/50/R15's and there should be no problems fitting RE002's on them. They ZE912's are sh.it tyres, I've used it before on another car - for day to day stuff they're fine. The Federals would either be 595SS (Super Steele's) which is good for street and not much else. Or it'll be the 595 RS-R's; will be about on par with RE002's and good for stret and track. Yes, I've used federals before. Anyway, to fit the Axis OG wheels, you're going to need roll the gaurds (look up Phil B Enterprises - he can roll gaurds and he can come to you). Once you have them rolled, you're more than likely going to need to lower it at least and run some camber bolts. Pedders can supply you them for around $100 for a pair of front or rears (you'll need both sets) and running -2.5 degree camber all 'round. For reference, my Corolla above was lowered 50mm at the front and 40mm at the rear to get the tyres to tuck. Good luck
  2. fastest: my brothers ride slowest: my carby powered AE92
