Search the Community
Showing results for tags 'ke70 4k'.
I’ve picked up an 82 ke70 4K and the previous owner has done some dodgy wiring. Looks like the main harness has been cut as well as lots of other dodgy stuff (pictured). When I try to crank the engine about 50% of the time I just get a little click (like when the battery is dead flat) and then the other times it only turns over very slowly (even hooked up to another running ae82) I think it’s something to do with the wiring cos it’s very dodgy and I’m not sure what the wires that have been cut or unplugged previously went. Some help identifying or pics of what the engine bay wiring is meant to look like would be great
- 7 replies
- ke70 4k
- wiring help
(and 1 more)
Tagged with:
G'day guys I'm fairly new to the k7 club, and may seem like an obvious question to most. But can someone with photos or simplified explanation on how I can hardwire my starter and power the button through a 12v switched supply, either head unit or something. It's only a temp fix, but I just want a simply way of drawings or something to, start the k7 with a push button, to bypass the ignition shit... That's stopping the car from cranking. Sorry if it's sounds dumb to you knowledgeable corolla enthusiasts, help is appreciated!
Hi i brought my grandmas 84 KE70 S model, it has stock 4K engine. runs smooth no problems until you get to a hill. The car will loose all power and stall out. even on a small slop you have to drop it back to 2nd and wont go any faster than 40. Could it just be the fuel pump or is it something big?
