kickn5k Posted November 26, 2006 Report Share Posted November 26, 2006 welding on ends it really sounds like too much stuffing around id get like an EN36A tool steel two rose joints and the left and right handed thread taps tap each end, on a mill cut 2 or 4 flats for spanner adjustment 2 lock nuts for the rose joints and it really is that easy i have made a set for a rear common whore(commodore) controll arms and not a weld anywhere. look hot and work really well. Quote Link to comment Share on other sites More sharing options...
styler Posted January 11, 2007 Report Share Posted January 11, 2007 (edited) rose joints are great when done properly, unfortunate that they are illegal on street though apparently its not due to them being strong enough but rather the adjustable side of things like if the adjustment retainer (nut) comes loose when you are driving along then the lower control arm gets loose and wobbly around the joint. someone mentioned they could be engineered for strength but I'm not sure that addresses the adjustable issue. lol on a more amusing side of things those eccentric camber adjuster bolt sets are sometimes undersize and flex or break, or just simply come loose and camber goes all over the place. when i first saw those sets i thought that may happen... at least they are only 1/2 deg or so, so hopefully no one has been injured from them coming loose. Edited January 11, 2007 by styler Quote Link to comment Share on other sites More sharing options...
irokin Posted January 11, 2007 Report Share Posted January 11, 2007 Gonna stop digging up months old threads yet?? Quote Link to comment Share on other sites More sharing options...
styler Posted January 11, 2007 Report Share Posted January 11, 2007 (edited) just this one really, easy dude! 2 months aint that long ago... Edited January 11, 2007 by styler Quote Link to comment Share on other sites More sharing options...
