welding on ends it really sounds like too much stuffing around id get like an EN36A tool steel two rose joints and the left and right handed thread taps tap each end, on a mill cut 2 or 4 flats for spanner adjustment 2 lock nuts for the rose joints and it really is that easy i have made a set for a rear common whore(commodore) controll arms and not a weld anywhere. look hot and work really well.
rose joints are great when done properly, unfortunate that they are illegal on street though
apparently its not due to them being strong enough but rather the adjustable side of things
like if the adjustment retainer (nut) comes loose when you are driving along then the lower
control arm gets loose and wobbly around the joint. someone mentioned they could be
engineered for strength but I'm not sure that addresses the adjustable issue.
lol on a more amusing side of things those eccentric camber adjuster bolt sets are sometimes undersize
and flex or break, or just simply come loose and camber goes all over the place. when i first saw those
sets i thought that may happen... at least they are only 1/2 deg or so, so hopefully no one has been
injured from them coming loose.
Edited by styler
