January 24, 200719 yr comment_160966 first find whch one is causing he problem: get a can of engine start & spray it down the intake, if it starts its the fuel giving you problems, if it doesn't start its the spark. try that to start off with Report
January 24, 200719 yr comment_161000 first find whch one is causing he problem: get a can of engine start & spray it down the intake, if it starts its the fuel giving you problems, if it doesn't start its the spark.try that to start off with Good reply but i suggest that you unplug yor injectors so you don't run them dry (incase there is no fuel getting to them). Report
January 31, 200719 yr comment_161886 - Fuel pressure high enough ? - Injectors not opening for some reason ? Report
January 31, 200719 yr Author comment_161888 well fuk me, I'm waiting for some responce from the megasuqirt forum before i do any more. I know its not the igntion or the timming anymore Its something to do with fuel and I'm just hoping its a minor fault in the ecu/programming that can be fixed. Report
