January 23, 200719 yr comment_160892 Hey guys I'm new to this forum..and need some help I'm here open for any ideas on what i should do, i currently have my hands on a 78 corolla coupe its immac the only thing is power wise... with a 3k motor 4speed box.. ive decided on a full engine change, i know i want to go bigger just not sure what will fit, i like the sound of a twin cam motor but not sure if they are a good fit..can ne1 help? what do u guys reccomend thanks...but i don't wanna spend stupid amounts of money on it though... I'm open for any suggestions .....as I'm goin to make this corolla tuff.. cheers adz Edited January 23, 200719 yr by ADZTOY Report
January 23, 200719 yr comment_160895 tuff for what kind of motor sport? coupe do you mean 2 door? Report
January 23, 200719 yr comment_160901 There is no such thing as a cheap engine conversion. Anybody will tell you that, but for a cheaper option, you could put in a 7k or 4age. Read through engine conversion forums, i'm sure that will help. Post some pics up of your car! gl Report
January 23, 200719 yr comment_160904 If your looking for power, i wouldn't waste money on a 4age engine conversion, as light as a corolla is 86kw aint ever going to make it that fast, and well can't seem to come across any small ports 4ag's and as for 20v your left with having a car that wont pass epa/engineering as 2 options are given to you due to the fact that the dizzy is on the back of the motor, aftermarket ecu with coil packs or modify the firewall, either of which aint gonna work in your case for it to be legal. Or you can mount the motor further foward and sacrifice handling. But that said a 4ag big port 86 is the cheapest of decent performance engine conversions, still going to be $$$ if you don't do the work yourself. Report
January 24, 200719 yr comment_160929 put a 308 in her then she will go fast........might be a little on the costly side thoe lol :) Report
January 24, 200719 yr comment_160932 tuff for what kind of motor sport? coupe do you mean 2 door? I don't think he said anything about any motor sport? And coupe means 2 door yes, it's most probably a KE35 like mine Report
January 24, 200719 yr comment_160935 If your looking for power, i wouldn't waste money on a 4age engine conversion, as light as a corolla is 86kw aint ever going to make it that fast, and well can't seem to come across any small ports 4ag's and as for 20v your left with having a car that wont pass epa/engineering as 2 options are given to you due to the fact that the dizzy is on the back of the motor, aftermarket ecu with coil packs or modify the firewall, either of which aint gonna work in your case for it to be legal. Or you can mount the motor further foward and sacrifice handling. But that said a 4ag big port 86 is the cheapest of decent performance engine conversions, still going to be $$ if you don't do the work yourself. To stop firewall damage get a CAS from a 4agze and stick that where the dizzy is on a 20v and use the 4agze coil packs. You also can fit the dizzy in if you do it right with firewall hackage. Edited January 24, 200719 yr by AE70 Report
