Diff Conversion Ke20
so with the mazda diff does it still require shortening? also what cars do the mazda e series diff come out of and what sort of hp can they handle?
cheers
Mazda L200 ute maybe ? I know the L200 diffs are used in Sigma's/Lancers but i don't know if its a E series ?
I run T-series diffs in both cars, but I know people using the Mazdas. I'll make some inquiries.
R
Hi Redwarf,
Did you end up finding the name of the place in NZ that sells the ratios / LSD for the T series? Would be interested to contact them with regards to prices for these.
Any leads would be appreciated.
Do you know the axle dia difference between the t series and the mazda (model ???) version.?
thanks
David
Yea ill be running a t series, with a mechanical centre i think it will be fine, the only weak point will be the k-50
